Use Generated Waveform as Path
Andy Benham
on Oct 11, 2018 at 12:18:03 pm
Hello all,
I'm using the AE waveform generator (playing in a 'white noise' file) for some technical videos I'm making to demonstrate a waveform.
Can I use this generated waveform as path for a cursor to follow, I want a 'dot' to ride along on this generated wave much like a traditional cathode-ray 'scope, whilst still displaying the wave.
Any pointers how I can do this, I've placed the wave-form on to a solid?
Kind Regards,
Andy.
Kalleheikki Kannisto
Re: Use Generated Waveform as Path
on Oct 11, 2018 at 2:00:54 pm
For a simple solution you could try making a copy of the waveform and then animate a vectical slit to move across the screen and use it as a track matte for the copy, essentially slicing a little section of the waveform to generate the "point". It may look just fine for your purposes.
Senior Graphic Designer
Michael Szalapski
on Oct 12, 2018 at 3:40:31 pm
I like this idea! A couple of linear wipes (offset from one another with an expression for ease of use) would get you a tiny slice. You could then apply blurs and/or glow effects to make a little dot traveling along the line.
- The Great Szalam
