An After Effects CC glitch, that came from nowhere!
Patryk Ming
on Oct 3, 2018 at 6:45:09 pm
Hi everyone!
I have a weird problem and the only way to describe it is by showing - link added below - two screenshots. In short... I'm making an animation in 3D and for some reasons these scratches showed up and I have no idea why. I was trying to move stuff around, with hope that they will disappear, but that sadly didn't happen. I'm not an expert, so there's a big chance for an easy explanation.
I so hope there's an easy way to make this problem go away. If anyone knows what's going on, then I'm bagging you... Let me know! 😓
https://imgur.com/a/b1fo4wX
Richard Garabedain
Re: An After Effects CC glitch, that came from nowhere!
on Oct 3, 2018 at 7:23:03 pm
link doesnt work..but have you restarted your computer? that usually helps
Patryk Ming
on Oct 3, 2018 at 7:53:53 pm
I've tried that and it didn't work. You can just copy the link instead of clicking it. The address itself works.
Patryk Ming
on Oct 3, 2018 at 10:51:28 pm
What I've noticed now, is that these scratches show up, only when I use Ray-Traced 3D renderer. When I go to Classic 3D, they simply disappear. So I assume that most probably my specs are the real problem.
