How do you make text letter counters transparent in After Effects?
Brian Welch
on Oct 2, 2018 at 9:15:34 pm
Working a project for a client and cannot find a way to blend the counters of the letters in my text with the background footage. In the 1st attached image, you can see I've created individual masks for each letter and their counters. I've set each of the counters to "Silhouette Luma" in the hopes of making them transparent, but as you can see in the 2nd image the counters just appear black when linked to Premiere. Has anyone else run into this issue and happened upon a solution?
Richard Garabedain
Re: How do you make text letter counters transparent in After Effects?
on Oct 2, 2018 at 10:42:26 pm
yes im confused too
Walter Soyka
on Oct 3, 2018 at 1:14:23 am
In typography, counters are the enclosed spaces inside of letters -- like the hole inside an O.
How are you constructing your letters that the counters are solid in the first place?
You could Extract, a luma matte, or the free Unmult effect from Red Giant Software to remove the black pixels instead of the silhouette alpha blend mode (which is dependent on the layer beneath and will not work across dynamic link).
Walter Soyka
Brian Welch
on Oct 3, 2018 at 4:37:43 pm
My apologies; here is the screenshot I originally meant to post. When linked with Premiere, the transparent counters appear black.
Walter Soyka
on Oct 3, 2018 at 6:06:23 pm
Right, thanks.
I'd suggest you try using Extract or luma mattes to create the transparency -- or maybe describe more about how you're making the letters in the first place, as we might have some other suggestions.
Walter Soyka
