How to connect/merge two layers
Jaroslaw Kaminski
on Oct 2, 2018 at 12:57:25 pm
I have had one layer, which I accidentally splitted into 2, using command ctrl+shift+d (the layer was selected as well, I didn't see that). I went further into animation and when I saw my error, I wanted to join these two layers together, but couldn't find an option. How to do that, but just simply connect them together, like I would hit Ctrl+z
Ken Teutsch
Re: How to connect/merge two layers
on Oct 2, 2018 at 1:07:50 pm
The original layer is still all there. Just drag out the end. Then you can delete the "split" version.
Eric Santiago
on Oct 2, 2018 at 3:22:21 pm
And if you did any extra attributes to the second layer e.g. keyframes, effects, etc... just copy and paste them to the final layer.
