HuffYUV or similar in AE or ME
Ian Collister
on Oct 2, 2018 at 10:37:09 am
Hi all
I remember some years back using the HuffYUV codec for rendering as it did no compression, or virtually no compression on my output files, this meant they rendered very fast (although the files where huge).
Is it still possible to output to HuffYUV or something similar that will give me quick renders?
Any help is as ever appreciated.
Ian Collister
Re: HuffYUV or similar in AE or ME
on Oct 2, 2018 at 10:41:42 am
Ignore. I thought it was no longer available. My bad.
Ian Collister
on Oct 2, 2018 at 10:45:15 am
Ahhh, but only for PC.
Well folks, it's been a rollercoaster.
cheers
x
Walter Soyka
on Oct 2, 2018 at 10:50:48 am
You can always render to Uncompressed (or to an uncompressed flavor of image sequences), but either ProRes or CineForm should provide a good compromise between quality and file size without adding too significantly to your render time.
Walter Soyka
Ian Collister
on Oct 2, 2018 at 12:47:53 pm
Thanks Walter. I found the completely uncompressed setting in the Quicktime options. That looks like it's giving me a pretty decent render time.
cheers
ian
