Can't add stroke to Mocha shape layer
Renato Soares
on Oct 1, 2018 at 10:50:39 pm
So, I generated a layer tracking on mocha ae and imported into AE, applied to my layer and everything is fine. However when I try to add a stroke (generate>stroke) the stroke simply does not appear.
I guess it's because it's not a Mask per say, but that's the only way I found on to copy the paths from mocha.
Renato Soares
Re: Can't add stroke to Mocha shape layer
on Oct 1, 2018 at 10:57:55 pm
I just noticed on a youtube tutorial that when they paste the shape data it turns into a Mask not a Layer like mine. I tried to paste it into a solid or even inside a mask but didnt work
Ross Shain
on Oct 2, 2018 at 7:08:23 pm
If you want to apply effects such as stroke to a Mocha generated roto shape, you need to "paste as an AE mask".
If you are running Mocha AE and have a roto shape on the clipboard, you will see 2 different paste options under edit menu:
Paste (pastes Mocha as Mocha shape plug-in - good for variable edge feathering)
Paste AE Mask - converts Mocha shape to AE mask
Ross Shain
Boris FX / Imagineer Systems
https://borisfx.com/products/mocha/
