Single-button vignette layer?
Eric Chard
on Sep 27, 2018 at 5:35:35 pm
Is there any tool/script that would generate a vignette layer at the touch of a button?
Ideally, such a tool would:
generate a full-comp black layer;
add an inverse mask to it;
feather the mask by some fraction of the X&Y;
possibly add some bezier corners and midpoints;
set the blending mode to DARKEN/MULTIPLY.
I think that's my whole wish list. I know I've written a lot of the pseudo-code above. The tricky bits would be making it universal for any shape comp.
But, thought I'd check FIRST.
"Putting the HARM in 'harmonica' since 2005."
Kalleheikki Kannisto
Re: Single-button vignette layer?
on Sep 27, 2018 at 6:55:11 pm
How about: Effects&Presets panel>Animation presets>Vignette Lighting
Senior Graphic Designer
Cassius Marques
on Sep 27, 2018 at 7:09:54 pm
Well, if you can do it with effects, the circle effect alone can get you 90% of the way, you could save it as a preset and just double click it anytime you want, without nothing selected it would create a comp size grey solid and apply. (You already have the Vignette Lightning preset to test it)
But really, how many times a day do you need that? Cause personaly I just do: Crtl + Y, set to black, double click round mask tool, Ctrl + Shift + I, "f" to feather. Its like 10s. Even though I have access to the Sapphire Vignette plugin thats pretty robust, I rarely use it.
Cassius Marques
http://www.zapfilmes.com
