Looking for a solution to create smoke on touchdown
Branislav Milic
on Sep 23, 2018 at 11:33:26 pm
Hi
I'm looking for a solution that can create the smoke generated by the rubbing tires of an airplane when it lands.
I made a little video that explains what I need: https://vimeo.com/291404542/c2c9b0da27
Thank you
Kalleheikki Kannisto
Re: Looking for a solution to create smoke on touchdown
on Sep 24, 2018 at 9:55:55 am
Trapcode Particular is my go-to solution for such. Smoke simulation is the other option, more realistic, but takes much more time, like on the order of 100 times longer.
Senior Graphic Designer
Eric Santiago
on Sep 24, 2018 at 12:54:19 pm
Depending on the camera move you can just a track a smoke comp w/alpha.
Typically how its done if you're in a pinch.
Stephen Smith
on Sep 24, 2018 at 7:36:18 pm
I agree with Eric. I like libraries like Videocopilots Action Essentials https://www.videocopilot.net/products/action2/. I used this technique to add smoke to the tires of the car slamming on its breaks in this
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Branislav Milic
on Sep 26, 2018 at 7:36:44 pm
Thank you all for your replies. I will have a deep look at it.
Eric Santiago
on Sep 26, 2018 at 8:12:15 pm
[Stephen Smith] "I agree with Eric. I like libraries like Videocopilots Action Essentials https://www.videocopilot.net/products/action2/. I used this technique to add smoke to the tires of the car slamming on its breaks in this "
Hey, good job Stephen ☺
If it works, do it!
That's my motto ;)
Stephen Smith
on Sep 26, 2018 at 8:22:03 pm
Thanks Eric.
Stephen Smith
