stretch time of Compositon not work ( MotionFactory plugin)
arioman manos
on Sep 23, 2018 at 8:31:24 pm
hi , i use free version of Motion factory and Type Builder Plugin for create some Text Effect
the Problem is the Time of Composition is too low ( about 2 sec ) , i want to increase and extend this time to more like 10 sec
I Try to use Time > Time Stretch on Composition , the Composition bar stretched but when i play it my text animation is still from 0 to 2 second and then show blank
Even i try to open composition and time stretch all layers but no success again
Mark Whitney
Re: stretch time of Compositon not work ( MotionFactory plugin)
on Sep 23, 2018 at 9:50:01 pm
Are you sure that what you want to do isn't actually just simply INCREASE the duration of the comp & not stretch it which generally changes time scale?
I suspect you are.
With your comp selected, hit Ctrl-K. That'll bring up your comp settings. Towards the bottom where it says Duration:, enter what you want there. It'll be frames or time depending on what you had set in the timeline.
