Sequencing Layers Offset
Nick Perry
on Sep 19, 2018 at 2:46:03 pm
Hi:
I was wondering if there was a way (or a script) to sequence layers so the time offset between them can increase or decrease?
For example, if I go to Keyframe Assist - Sequence Layers and set the overlap accordingly I can sequence my 10 layers with say a 20 frame gap between the start of each.
Is it possible to quickly apply a way to sequence the same layers but so that the duration of the gap decreases with each step - ie
Layer 2 comes in 20 frames after Layer 1
Layer 3 comes in 18 frames after Layer 2
Layer 4 comes in 16 frames after Layer 3
Layer 5 comes in 14 frames after Layer 4
thank you
Nick
Walter Soyka
Re: Sequencing Layers Offset
on Sep 19, 2018 at 6:57:31 pm
Have you seen Rift?
https://aescripts.com/rift/
Walter Soyka
Nick Perry
on Sep 20, 2018 at 8:09:44 am
Walter
Thank you so much - that is exactly what I needed
Kind regards
Nick
