Dip in grid - gravity effect
Mario Colantonio
on Sep 18, 2018 at 9:22:55 pm
Greetings everyone!
I am Mario, writing from Germany, I try to spend some time having fun with this wonderful software.
I can't wrap my head around how this effect was obtained:
it comes straight from a Kurzgesagt video (I know, I know, it's probably top tier animation).
I really can't make up an idea on how to deform just some spots of the grid, let alone move this dip around.
Does someone know how it could be done, if at all it can be done in AE?
Walter Soyka
Re: Dip in grid - gravity effect
on Sep 18, 2018 at 10:46:59 pm
I'd recommend a third-party plugin from Mettle, FreeForm Ae:
https://www.mettle.com/product/freeform/
Walter Soyka
Kalleheikki Kannisto
on Sep 20, 2018 at 7:51:26 pm
Since there's no perspective, an animated displacement map is a viable option -- not that it is necessarily easy to figure out what the displacement map should look like, but once you have one figured out for a single "dip", you can copy it, scale it, change opacity and move it around to create the gravity warping effects.. Also, it would need a separate layer for anything that peeks down from the underside. 16 bits for smooth displacement.
Senior Graphic Designer
Richard Garabedain
on Sep 21, 2018 at 4:26:57 pm
I might try the puppet tool on a grid...most tedious part will be putting all the points in place but then it ...actually i dont know if this would work in 3d space.
Mario Colantonio
on Sep 22, 2018 at 11:58:26 am
I thank you all, I'll give a try to these solution!
