AE crashes and Premiere low level exception error
bart stevens
on Sep 18, 2018 at 5:03:40 pm
I'm having issues with both After Effects and Premiere.
In Premiere, my project works fine for a while (maybe 15 - 20 min). Then I get a "low level exception error".
I can save the project, but my cineform files are not readable. When I reopen the project, files are fine (for a while) then same thing happens.
If I import the Project into After Effects, I get the same problem, but cannot save.
I'm working with both new and older cineform files. I'm not a hundred percent certain, but think the problem is mostly with older cineform avi files, maybe a conflict with the codec?
Shouldn't both Premiere and After Effects be able to read cineform files natively?
At some point I wasn't able to play older cineform avi files, so installed a older version of the codec. Then I could read the files, but now I'm getting these crashes.
I've tried reinstalling several times and rolling back to earlier programs, turning off CUDA in project settings, clearing cache... etc...
Anyone have a similar problem?
Here's the crash data:
Premiere:
A low-level exception occured in: Importer AVI (Importer:47)
Adobe Premiere Pro.exe
12.1.2.69
5b34ba17
ntdll.dll
6.1.7601.24214
5b6273e1
c0000374
00000000000bf6b2
4d6c
01d44a0c29cbaca7
C:\Program Files\Adobe\Adobe Premiere Pro CC 2018\Adobe Premiere Pro.exe
C:\Windows\SYSTEM32\ntdll.dll
52c6d24b-b600-11e8-8aad-989096ae209b
After Effects:
Problem signature:
Problem Event Name: APPCRASH
Application Name: AfterFX.exe
Application Version: 15.1.2.69
Application Timestamp: 5b35ca62
Fault Module Name: StackHash_9782
Fault Module Version: 6.1.7601.24231
Fault Module Timestamp: 5b6db5a7
Exception Code: c0000374
Exception Offset: 00000000000bf302
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 9782
Additional Information 2: 9782935300ff3de25ffed55ec0e933fb
Additional Information 3: d85f
Additional Information 4: d85fe3117521d458fce67542c0bd2813
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Event viewer:
Details:
AfterFX.exe
15.1.2.69
5b35ca62
ntdll.dll
6.1.7601.24231
5b6db5a7
c0000374
00000000000bf302
152c
01d44ef6cb135f59
C:\Program Files\Adobe\Adobe After Effects CC 2018\Support Files\AfterFX.exe
8febfd58-baea-11e8-b5b7-989096ae209b
General:
Faulting application name: AfterFX.exe, version: 15.1.2.69, time stamp: 0x5b35ca62
Faulting module name: ntdll.dll, version: 6.1.7601.24231, time stamp: 0x5b6db5a7
Exception code: 0xc0000374
Fault offset: 0x00000000000bf302
Faulting process id: 0x152c
Faulting application start time: 0x01d44ef6cb135f59
Faulting application path: C:\Program Files\Adobe\Adobe After Effects CC 2018\Support Files\AfterFX.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 8febfd58-baea-11e8-b5b7-989096ae209b
