Better ways instead of key-framing?
John Wooltorton
on Sep 16, 2018 at 7:14:58 am
Hey everyone, so I have created a "magical particle trail" and a "magical ball". The particle is emitting from the light which is parented to the null object called "emitter". Now I want the magical ball to follow along the beginning of the particle trail but don't want to keyframe it because I am lazy (lol). I tried parenting the magical ball to the null object but it is not precise. Are there any better methods than just keyframing?
https://imgur.com/a/bK8YUwU
Thanks for any help!
Kalleheikki Kannisto
Re: Better ways instead of key-framing?
on Sep 16, 2018 at 1:11:03 pm
Option 1: Make the "magical ball" a 3D layer. If need be, set it to auto-orient to camera.
Option 2: Use an expression that converts 3D position to 2D screen position. You should be able to find it by searching in this or in the expression forum.
Senior Graphic Designer
