Problem with Auto Orientation
Nessi Bennet
on Sep 13, 2018 at 5:02:58 pm
Hi ,
im a Beginner with After Effects. I create a animated map. My problem is when I move one of the objects its starts to disappear, I don't know how to put it in words but I made a screenshot for you...how can I solve that?
Kalleheikki Kannisto
Re: Problem with Auto Orientation
on Sep 14, 2018 at 8:51:07 am
That image (which is not linked in your post, btw), doesn't give much information. All I can surmise from it is that your map base plane has possibly been accidentally rotated so that it is at an angle and the sign gets cut off by the plane. Check the rotation values of the base plane, and if your base plane is attached to a null, check the rotation values there too. But that's just a guess.
Senior Graphic Designer
