Stationary Echo Effect
andy baumgartner
on Aug 31, 2018 at 7:45:32 pm
Hi, I would like to create an effect similar to "echo" but instead of animated echos, each echo would be a freeze frame. The effect would take a rectangle and produce a trail of rectangles, with another being "dropped behind" ever few frames.
There are too many echos to do it manually.
Does anyone know how to achieve this?
-Andy
Michael Szalapski
Re: Stationary Echo Effect
on Sep 4, 2018 at 6:27:41 pm
If you're just trying to drop rectangles, there are a number of ways to do it. Any of several particle effects would do it pretty easily.
- The Great Szalam
andy baumgartner
on Sep 4, 2018 at 6:48:44 pm
Hey Michael, I am animating the field of view of a satellite as it rotates around the earth in Cinema 4D, so the shape is constantly changing (as the satellite comes around the earth sphere the rectangular field of view it projects on the earth is very oblique with respect to the stationary scene camera, then it gets more like a rectangle as it comes around.)
I should have mentioned it is footage from Cinema 4D, not a simple rectangle.
Kalleheikki Kannisto
on Sep 5, 2018 at 10:25:46 am
I would try and do this with a sub-comp at 1 fps with the echo effect on top of your main footage at original fps.
Senior Graphic Designer
andy baumgartner
on Sep 6, 2018 at 12:55:24 am
Thanks Kalleheikki. I'll keep that in mind next time a do a similar shot.
andy baumgartner
on Sep 6, 2018 at 12:52:43 am
Here is the effect I was trying to create for reference. I ended up doing it in Cinema 4D.
