AE to WebM?
Jamie Ortiz
AE to WebM?
on Aug 30, 2018 at 6:20:32 pm
Hi!
I'm creating animations for web in AE with transparency (animated buttons with text, animated illustrations, etc.). I have been using the Apple ProRes 444 codec, then using a converter to convert to webM but found that there are some issues with transparency when testing on web. Should I be using the Animation codec instead? And what is the difference between them?
Thanks in advance!
- Jamie
Dave LaRonde
Re: AE to WebM?
on Aug 30, 2018 at 8:15:50 pm
ProRes 444 doesn't support alpha channels, for one thing. However, ProRes 4444 does.
As for differences, The ProRes family of codecs is 10-bit. Animation is 8-bit. That may not matter. But if you're making animated buttons & animated drawings, Animation may produce more compact file sizes because of the way it encodes.
Dave LaRonde
Promotion Producer
Walter Soyka
Re: AE to WebM?
on Aug 31, 2018 at 10:50:56 am
It's possible that your converter application is introducing the issue. Have you tried the WebM plugin for Adobe Media Encoder?
https://www.fnordware.com/WebM/
Walter Soyka
