Substituting a 3D solid layer from a AFX comp with a video in Premiere
Emil Stef
on Aug 23, 2018 at 1:05:51 pm
Hi folks!
My first question is quite tricky and I have tried everything possible but no success so far.
Here's the issue.
I have a 3D comp in After Effects CC2018 with a camera and a 3D solid layer that's flying around (1920x1080, as a place holder).
I have imported the 3D comp in Adobe Premiere Pro CC2018 and would like to substitute the 3D solid layer with a video footage from Premiere Pro (I guess from a specified video track).
For now several ideas came to my mind as a solution (exporting the 3D Comp as a 2D corner pin data but how do I get it into Premiere)... So far no real solution. The question is: how do I get the link between AFX and Premiere with this one?
Any ideas? I would be super thankful for awesome suggestions!
Best regards
Emil
Kalleheikki Kannisto
Re: Substituting a 3D solid layer from a AFX comp with a video in Premiere
on Aug 24, 2018 at 1:22:49 pm
Replace the 3D solid in After Effects with your footage of choice.
Senior Graphic Designer
Emil Stefanow
on Aug 24, 2018 at 1:26:25 pm
Hi Kalleheikki,
Thank you for the answer! ☺
How do I replace a AFX Solid with a footage in Premiere (not FROM Premiere but IN Premiere)?
Thank you!
Best regards
Emil
on Aug 24, 2018 at 1:35:44 pm
Why do you want to do it in Premiere?
Emil Stefanow
on Aug 24, 2018 at 1:40:44 pm
The customer doesn't have After Effects and I would like to deliver a kind of a template where he can just substitute the footage. Also possible with Essential Graphics?
Thank you!!!
on Aug 24, 2018 at 1:43:57 pm
Ok, this would then be a question for the Premiere forum.
on Aug 24, 2018 at 3:28:36 pm
I kinda suspect you will have to manually animate using Premiere corner pin to try and match the AE render.
Emil Stefanow
on Aug 24, 2018 at 3:33:17 pm
Thank you Kalleheikki,
That's my suspicion, too. Unfortunatelly.
I don't think it's possible to "transfer" the corner pin data from AFX into AE directly, or? That would be a big help.
Best regards
Emil
Dave LaRonde
on Aug 28, 2018 at 6:18:54 pm
This may be a bit late in the game, but I'll bet your client's running something newer than CS6. In which case the client CAN get AE. It's just a matter of downloading & installing it.
Dave LaRonde
Promotion Producer
Emil Stefanow
on Aug 29, 2018 at 10:24:35 am
Thank you Dave.
Unfortunatelly the customer doesn't have any AFX knowledge (and the AFX setup isn't that easy for a newbie.
So I guess we stick to the AFX solution and deliver a final video. :/
Best regards
Emil
