Is it possible to edit a footage file path without replacing it, using javascript?
Siddhartha Nayanananda
on Aug 20, 2018 at 5:15:34 am
I have a big amount of Ae projects that has missing footage problem. I already made a script to find and replace missing footages but still needs to go through PSD layers because I didn't find a way to script it to replace and link specific PSD layers. So
Is there any way we can edit file paths that saved in a project file? Without going through replacing them?
Like, Foundry nuke has a path section that we can always edit to direct it. sorry for bringing nuke to the discussion but could someone let me know? Thanks. Cheers!
Walter Soyka
Re: Is it possible to edit a footage file path without replacing it, using javascript?
on Aug 20, 2018 at 2:30:17 pm
If you use File > Save as > Save a copy as XML, you'll be able to use standard text tools to search and replace file names in the resulting AEPX file.
Walter Soyka
on Aug 20, 2018 at 5:41:49 pm
Hey Walter,
Thank you so much for taking time to replay. Seems like this is the only way to do this. Thanks again for the help.
Cheers!!
