How can I change 3d object anchor point position in Element 3d?
Hubert Niedbala
on Aug 17, 2018 at 9:35:15 am
Hi everyone!
Hi everyone, I have a odd and probably simple question for advanced, but I have a problem with that and I need help. My question is how can i change 3d single object anchor point in "effect control" window in element 3d plugin. I trying to rotate single object, but when doing this, my object is rotating to the bottom point. I need this point in the center of the box, to do it around your axis. How can I do this? I ask for help in this case.
Thanks! ☺
Richard Garabedain
Re: How can I change 3d object anchor point position in Element 3d?
on Aug 17, 2018 at 4:46:53 pm
in the scene setup each object as an alignment...middle bottom top...etc..if these options are not specific enough there is also and anchor point coordinates section..in the scene setup
Kalleheikki Kannisto
on Aug 18, 2018 at 9:45:13 am
Additionally, you can manually move the anchor point in Scene Setup by using the lock transformations toggle in the toolbar unders the preview. The Gizmo turns orange and you can drag it to move it where you need to. Use the planar views to align with better precision.
Senior Graphic Designer
