Custom Text Animation
Georgi Todorov
on Aug 17, 2018 at 12:41:35 am
Hello Creativecow people!
I am trying to find a solution about a custom text animation that I am creating.
Here is my gif as an example of what I am talking about (the second example in this gif has an echo effect applied).
https://imgur.com/a/0NBVuIR
I did this example using a really bad method - by applying the layer animation to each letter individually with bunch of precomps and aligning them by hand... yeah... I had to give an example at least. This method could also work, however it is a permanent effect and if I want to put a different text for a different client, I have to do things by hand each time. I am looking for a simple automated solution, that would do this job without the hassle of applying individual letter animation with precomps, like I did in my example. I am aware of the text animator, however I cant get it to work properly the way I want to. Maybe I'm doing something wrong?
Thank you,
Georgi
Andrew Somers
Re: Custom Text Animation
on Aug 17, 2018 at 10:02:29 am
Is it the long trails that you are after? Then you can use the ECHO plug in.
https://helpx.adobe.com/after-effects/using/time-effects.html
You can also use motion blur to a similar effect, as I discuss in this article.
And then finally, a script or expression might do you well, here's one example:
http://www.motionscript.com/mastering-expressions/follow-the-leader.html
Andrew Somers
VFX & Title Supervisor
http://www.GeneralTitles.com
