Displaying a specific layer from a nested comp
George Henderson
on Aug 15, 2018 at 9:25:46 pm
Hi everyone,
Is there an effect or script that can display a certain layer from a nested comp? For example:
1. I have two layers in 'Comp A' (1. Text & 2. Logo).
2. I drop 'Comp A' into 'Comp B'
3. Can I add an effect to the nested 'Comp A' to only display (1. Text)?
Usually, I would duplicate 'Comp A' into two parts ('Comp A - Text' & 'Comp A - Logo') and drop the two into 'Comp B'.
Looking forward to your response, thanks!
Andrew Somers
Re: Displaying a specific layer from a nested comp
on Aug 16, 2018 at 7:03:19 am
This is easily done with an expression.
On the CompA layer inside CompB for instance, you can refer to the CompA layers and manipulate them via the expression (and whatever controls you set up for the expression), including visibility, opacity, etc.
Expressions are easy to write Javascript with some specific functions added for After Effects. And in fact much of the time you need to do very little writing of code, as you can "pickwhip" to create all sorts of custom controls.
Here's a "No Writing" version (just pickwhip):
As an example, you could add a "Slider" control to the CompA layer (inside CompB) and it appears as a slider in effects controls, then pickwhip the Opacity of one of the CompA internal layers to that control. On this slider control in CompB you can add further expressions/keyframes to that same control, allowing you to control the internal layer of CompA while in CompB.
If this is something you do a lot, you could even save it as an "animation preset".
If you would rather use the checkbox to just toggle from 0 to 1 opacity, then you do need just a tiny bit of code:
if(comp("CompB").layer("CompA").effect("Checkbox Control")("Checkbox").value) 100 else 0;
This code assumes that CompA is nested inside CompB and the CompA layer has the checkbox added to it. The IF statement sets the return value to 100 if the box is checked, and 0 if not.
If you're wondering, the checkbox can't be pickwhipped to thevisibility (layer enable) button, as expressions can't access it — however SCRIPTS can access the visibility button, so you could develop a script instead, not sure which is best for you.
All this said, I'm not sure from your example what you're really trying to accomplish?
Andrew Somers
VFX & Title Supervisor
http://www.GeneralTitles.com
George Henderson
on Aug 21, 2018 at 6:05:17 pm
Hi Andrew,
Thanks for your thoughtful response. I just tried the checkbox method and it partially works; unfortunately, it's not doing what I am trying to achieve.
The problem is... the 'CompA' layer within 'CompB' will display whatever that's being displayed within 'CompA'. My goal is to call up whichever layer from one master comp and only have that layer be displayed no matter the visibility of the rest of the layers within that master comp.
I have attached a sample project to further explain the problem. 'CompA - Logo' should only display the logo, but since the checkbox on 'Comp A - Hello' is ticked, it shows both hello and the logo.
12661_layerdisplay.aep.zip
Walter Soyka
on Aug 22, 2018 at 9:19:10 am
[George Henderson] "Usually, I would duplicate 'Comp A' into two parts ('Comp A - Text' & 'Comp A - Logo') and drop the two into 'Comp B'. Looking forward to your response, thanks!"
That's the way I would handle it, too, but starting with Ae CC v15.1, you do have a new option: Master Properties.
Master Properties is a new feature that lets you control specific properties of a comp when it's nested in another comp. I think of it like instancing a comp, with a few tweakable parameters. Here's the basic workflow:
1. With the Essential Graphics panel, identify the properties in the master comp that you'd like to be able to change from within other comps.
2. Use the master comp as a layer in other containing comps. Twirl open its layer properties, and adjust/keyframe the master properties you made available in the first step. Each comp layer will render an instance of the master comp, with the adjustments you've made in the timeline.
Here's a quick intro to Master Properties:
Here's the documentation:
https://helpx.adobe.com/after-effects/using/creating-motion-graphics-templa...
Here's a screengrab from a setup I've done based on your comp. (It uses checkboxes to control layer visibility in the master comp. Note that they exist only in Comp A, and can be freely and independently manipulated in Comp B):
And here's the AEP:
12664_layerdisplaymasterproperties.aep.zip
Walter Soyka
George Henderson
on Aug 22, 2018 at 6:36:37 pm
Oh wow, that's it! I had no idea 'Essential Graphics' existed.
Just watched several videos and played around a bit, it certainly does the job and so much more.
Thanks for exposing me to such handy feature. greatly appreciate it Walter!
Walter Soyka
on Aug 22, 2018 at 7:00:19 pm
[George Henderson] "Oh wow, that's it! I had no idea 'Essential Graphics' existed. Just watched several videos and played around a bit, it certainly does the job and so much more. Thanks for exposing me to such handy feature."
I think Master Properties is the biggest improvement to Ae since CS5 (when Ae went 64-bit).
It's a sneaky-powerful feature that can completely change the way we approach our work.
Walter Soyka
