how to create a random opacity for triangle BG
Manish Choudhary
on Aug 11, 2018 at 11:20:40 am
i have a project were client need random opacity in its BG
any suggestion how to create it in AE
i created pattern what client needs but now how to animate it.
video has to be like mentioned link
ref.
Kalleheikki Kannisto
Re: how to create a random opacity for triangle BG
on Aug 11, 2018 at 4:19:37 pm
Using this free stock video does not work because ... ?
Senior Graphic Designer
Steve Bentley
on Aug 11, 2018 at 5:19:53 pm
You can use the wiggle expression on the transparency attribute. Use a long period (time between "changes") and you may have to set min and max of 0 and 100. You may also have to round off the result as opacity only takes positive integers.
