I did something and I don't know how I did it?
Richard Garabedain
on Aug 9, 2018 at 6:33:05 pm
So my preview was going super slow so I decided to hold shift and skip 10 frames at a time. i did this for a little bit and then i accidentally hit some button that started ram previewing through those frames and only those frames...so i was essentially previewing it at skip 10 frames...and ram preview only goes up to skip 5 frames...naturally i tired to replicate what happened and i could not
Kalleheikki Kannisto
Re: I did something and I don't know how I did it?
on Aug 9, 2018 at 8:49:12 pm
That will happen if you hold shift when clicking on the preview button.
By the way, you can type any number in the skip frames box, as I learned recently.
Senior Graphic Designer
Richard Garabedain
on Aug 9, 2018 at 9:32:18 pm
Well ill be a monkey's uncle..I "can" type any number in there. Says after using after effects for 6 years
