Replacing .PSD and .AI files do not work the same way in Adobe After Effects?
Nikola Tomic
on Aug 9, 2018 at 3:49:50 am
Hello to all.
How can I replace footage in Adobe After Effects? With .PSD files it works all well (CTRL + H and select changed .PSD file with the same number of layers, same size, just small colour corrections...). But when I try to do the same with .AE layered file - it won`t work!?!?
Please help, I've spent more than 6 hours trying to do faster than manually layer by layer change...
In short:
1) I create layered character in Illustrator then import in Adobe AfterEffects as: Composition - Retail Layer Sizes - it creates composition and it is all understandable - I easily animate or rig character. But the problem is - when I try to REPLACE FOOTAGE - I can only see - IMPORT AS FOOTAGE while other options like "Composition - Retain Layer Sizes" simply does not exist in "Import As" menu (!?) For example - I created COPY of Character V1 (named V2.ai) file where I changed only colours of all layers and I expect to replace .AI file (as I do with layered .PSD files) and have the same animated character but with different colours?
What is the trick? I've tried all ALT + CLICK possibilities - none of them works. I can ALT + CLICK and replace layer by layer...
Will "Collecting whole project" to one directory solve the problem? For example - I collect all for output on Desktop directory named "Character 1" directory. Then I clone (Copy & Paste and then rename "Character 1" to "Character 2" desktop directory and import the same .AE file (with the same sub-files including .AI file with changed colours)? If this will work - what might happen if I plan to import two the same named projects into NEW After Effect project and try to have two characters in one .AE project?
I hope you understand my question... and problem. Is there any solution? Maybe some script or something if this feature is missing?
Nykk Deetronic
http://www.youtube.com/djnykk
Andrew Somers
Re: Replacing .PSD and .AI files do not work the same way in Adobe After Effects?
on Aug 9, 2018 at 9:32:18 am
There is not a command that does what you want, BUT:
You CAN use a HEX editor to modify the file path and file name of the AI file in the AE project. I use the app "0xED".
http://www.suavetech.com/0xed/
NOTES:
  • Do not rename the layers and do not change their order.
  • Always work in a COPY of your AE project — it is very easy to destroy the project so it won't open.
  • Anchor point positions may not be maintained and need to be re adjusted in some cases.
Good luck!
Andrew Somers
VFX & Title Supervisor
http://GeneralTitles.com
Nikola Tomic
on Aug 9, 2018 at 11:47:30 pm
Thank you very much!
This is what I did (just in case) and then tried your solution: I first COLLECT to output - FILE 1 and set to Desktop. Then I opened renamed (the same project) to FILE 2, go to File 2 dir and replaced old .AI file with new one where I corrected colours (even a bit of changed shape but in size of old layer - to all layers.
1 - This way I got - FILE 2 like I wanted, but with THE SAME NAME as in FILE 1 (if you understand).
2 - THEN I tried your solution: I copy/pasted (made backup) and opened FILE2.aep with right mouse click: EDIT WITH NOTEPAD++
- FILE2.aep opened in Notepad++ (free and also excellent PC program for correcting html / css without changing source!)
- Then I find FILE1.ai (CTRL + F) - Notepad++ found 40 FILE1.ai listings in .AI file.
- Go to tab - REPLACE and entered "Replace FILE1.ai with FILE2.ai" and click SAVE.
When I opened FILE2.aep from Desktop - IT WORKED!!! Thank you for your suggestion - it would never come to my mind to edit source .aep file ☺
p.s. Why Adobe do not implement this? It would save many problems (as it works perfectly with .PSD)?
Thanks again!
Nykk Deetronic
Andrew Somers
on Aug 10, 2018 at 12:34:23 am
Glad it worked!
I'm surprised that Notepad++ worked to edit the aep file, as on MacOS I need to use a hex editor for the aep file (not even BBedit works without corruption). Notepad++ must preserve the binary data somehow. Or did you save as .aepx ?
When I wrote the response yesterday I forgot that you can save a project as XML and easily edit in any text editor.
And as I look into this, I see that doing it via an XML version is by far the better way to go, as it's safer and preserves important settings.
And THEN I just remembered that this is something that is scriptable, and here's a script that can do it:
https://aescripts.com/batch-search-n-replace-paths/
And if you wanted to write a script, here a bit from the scripting guide:
app.project.item(index).layer(index).replaceSource (newSource, fixExpressions)
Description:
Replaces the source for this layer.
Parameters:
newSource
The new source AVItem object.
fixExpressions
True to adjust expressions for the new source, false otherwise. Note that this feature can be resource-intensive; if replacing a large amount of footage, do this only at the end of the operation. See also "Project autoFixExpressions() method" on page 115.
Andrew Somers
Chris Gomersall
on Aug 9, 2018 at 5:56:49 pm
If I understand you right...
Import the updated art into your project. Select the layer/pre-comp/comp (whichever) to want to update in the project timeline. Hold down option key and drag updated file from the project window to OVER the selected layer/pre-comp/comp (whichever) in the timeline and release. If it has same size, layers, anchor points it should update it in place.
Or not. Sorry if I misunderstood the issue.
~CG
Kind regards,
Chris Gomersall
gomersall.chris@gmail.com
817-944-4124
http://www.vimeo.com/channels/texasvideopro
Nikola Tomic
on Aug 9, 2018 at 11:51:20 pm
Yes but it works perfect with cloning Precompositions AND with this new file but I have to manually add layer by layer (drag and then ALT + drop) which is sloooow process because my rig has over 40 layers.
Replacing (CTRL + H) old PSD file with new .PSD file (where I changed all graphics and leave layers with the same names and more/less the same size) works perfectly but CTRL + H will not allow me to replace .AI layered file... I will be able to manually replace FOOTAGE and select LAYER SIZE and find its name which will lead me to 1-2-3 hours work more than it is automated as expected. ;)
Nykk Deetronic
