expression using markers to animate position not working
mel ruiz
on Aug 8, 2018 at 8:29:03 pm
I'm trying to have the position of a shape follow a null between two markers on a marker layer. (So, I have a shape layer, a null for movement and another null with markers on it.
I used the expression below for the position of my shape layer, but even though this position:
thisComp.layer("ball control").transform.position.valueAtTime(endTime)
isn't changing after the endTime, the shape moves once the null object moves after that time.
Any idea what's happening? Thanks so much!
beginTime = thisComp.layer("MARKERS").marker.key("beginTime1").time;
endTime = thisComp.layer("MARKERS").marker.key("endTime1").time;
if (time < beginTime)
thisComp.layer("ball control").transform.position.valueAtTime(beginTime)
else if (beginTime <= time < endTime)
else
Kalleheikki Kannisto
Re: expression using markers to animate position not working
on Aug 9, 2018 at 12:43:39 pm
Modify you "else if" like this
else if (beginTime <= time && time < endTime)
As I understand it, only the first part of the else if comparison (beginTime<=time) was evaluated the way you had it written.
Senior Graphic Designer
mel ruiz
on Aug 9, 2018 at 3:47:35 pm
worked! thanks. : )
