Eye-dropper / colour-picker troubles ? This solved it for me
Filip Vandueren
on Aug 8, 2018 at 8:35:37 am
There's this very frustrating bug where the eye-dropper in for example the type-tool can only pick-up colours from the after effects interface, but nothing from inside a comp- or footage-viewer.
Which would be the entire point of the tool…
Changing the bit-depth of the project, even if you then revert to the previous, fixed it.
So the quick shortcut-y fix is to alt-click 3 times on the 8bpc/16bpc/32bpc indicator in the bottom row of the project pane.
Hope this helps cow-members.
some keywords for future search:
eyedropper
eye-dropper
colorpicker
colourpicker
pipet
