Importing ps 3300 x 2550 into ae while converting to 1920 x 1080 and keeping layer sizes
Diane DeBoer
on Aug 7, 2018 at 9:57:51 pm
I imported multiple files using import as: composition - retain layer sizes. The photoshop files originated as 3300 x 2550. The ae composition is 1920 x 1080. The first time I imported them they converted to 1920 x 1080, retaining the layer sizes so everything fits perfectly in the frame.
Subsequent attempts resulted in the size within the 3300 x 2550 ratio. For example: (1650 x 1275). Please advise how to retain the layer sizes going from 3300 x2550 in ps into 1920 x 1080 in ae.
Thanks.
Diane
Dave LaRonde
Re: Importing ps 3300 x 2550 into ae while converting to 1920 x 1080 and keeping layer sizes
on Aug 7, 2018 at 11:17:22 pm
I would begin by double-checking pixel aspect ratios. They should be square in both applications, i.e. a pixel aspect ratio of 1.0.
I'm at a loss to explain why a 3300 x 2550 Photoshop document would be automatically be converted to 1920 x 1080. Not once in my experience has AE done anything like that.
Dave LaRonde
Promotion Producer
Andrew Somers
on Aug 8, 2018 at 2:13:41 am
As a matter of practice, I recommend importing PS files and placing into a layer at the native resolution of the PS file. Then place that entire layer into another comp that is at the output resolution, and scaling the PS layer as needed.
Andrew Somers
VFX & Title Supervisor
http://GeneralTitles.com
