Fail to track in Mocha problem solved
Emmanuel Akinola
on Aug 2, 2018 at 12:27:19 pm
Hello guys, I am Emmanuel Akinola. Having sharing the same problem of Mocha not opening some video formats I later come across a solution that works for me which I believe will work for virtually everyone having the same problem with mocha in A.E. Just download and install QuickTime 7.7.9 offline installer, then run A.E and and track i Mocha. Problem solve.
Ross Shain
Re: Fail to track in Mocha problem solved
on Aug 8, 2018 at 6:13:08 pm
Here is a tech note that covers Mocha footage support:
https://borisfx.com/support/documentation/mocha/5.6.0/#_what_to_do_if_mocha...
If you are running the Mocha Pro plug-in inside AE, all footage that the Adobe media engine supports will work with Mocha.
If you are running the bundled Mocha AE (which is a standalone application) some file types are not supported.
Ross Shain
Boris FX / Imagineer Systems
https://borisfx.com/products/mocha/
