AE Shortcut wont open media encoder (ctrl+alt+M)
Jeroen Rommelaars
on Aug 2, 2018 at 7:53:30 am
Hey guys,
I was hoping someone knows a fix for this issue.
I just built a new computer, did a clean install of win10 pro, and a clean install of all adobe apps, including AE18 and Media Encoder 18.
The only problem I have is that the shortcut to add the current comp to the media encoder queue (ctr+alt+m) doesnt do anything.
I checked in the shortcut menu, and yes, it is listed.
Anyone have a fix for this very silly issue? Its kinda timeconsuming to have to click edit->add to queue for each comp when i have to render a load of comps 😉
ps. this issue is apparently a bit more common, as can be seen by this thread on the official forums. https://forums.adobe.com/thread/2395804
Of course, I posted there as well, but I have much higher hopes of a quick response on these forums than on the official ones 😉
pps. Even a fresh install of both AE and ME didnt work.
ppps. Adding a custom shortcut to the command (ctrl+alt+SHIFT+m) makes it work again. Not ideal, but ey, working for now :)
Any help is much appreciated!
Cheers!
Neal Strydom
Re: AE Shortcut wont open media encoder (ctrl+alt+M)
on Aug 6, 2018 at 1:44:51 pm
I thought this was just my PC doing this for some time, but then I saw it was permanent on my end and now I just use the menu.
I think it will be fixed in a bug-fix patch. Or I would hope so. My advice would be to just hang ten until they roll out a fix and like you said, you did report it, so they should see to it in their next patch roll-out.
