Keyframes in between frames?
Nicholas Campbell
on Jul 31, 2018 at 5:47:33 pm
So I'm working with a template and I've noticed that some of the keyframes are in between frames. I've added a screenshot of what I'm talking about. I'm zoomed in the way btw. Another weird thing is that my playhead is not on the keyframe, yet it says I am if you look to the left. Is there a way to adjust my settings for this?
Cassius Marques
Re: Keyframes in between frames?
on Jul 31, 2018 at 7:19:46 pm
This is normal behavior, It actually happens a lot when you create a project with a defined fps value and change it later on.
If it ain't causing trouble you can just leave it as it is... You're still able to change that keyframe value without changing its position in time. Or you could drag it and AE will snap it to the closest full frame.
Cassius Marques
http://www.zapfilmes.com
