Font square problem
Onur Uygur
Font square problem
on Jul 28, 2018 at 9:35:37 pm
Hi all,
Whenever I write something in AE, Im seeing little squares in the font. Is there any way to solve this problem. You can see the problem in the image. Thanks
Corey Curry
Re: Font square problem
on Jul 29, 2018 at 2:35:22 pm
It's probably your monitor. I can't see any squares in the fonts. Probably want to calibrate your monitor http://www.lagom.nl/lcd-test/
Onur Uygur
on Jul 29, 2018 at 4:34:47 pm
I checked my monitor. All is good with that. The problem is, as you can see F is so straight there is no problem with that. But A is not. There are a lot little square in the A. Im sometimes seeing this problem sometimes not? Do you have any idea why is that?
Onur Uygur
on Jul 29, 2018 at 9:06:31 pm
Dave LaRonde
on Jul 30, 2018 at 5:09:59 pm
[Onur Uygur] "Im sometimes seeing this problem sometimes not? Do you have any idea why is that?"
Yes. Your comp resolution is set to something less than Full, or your comp is zoomed into more than 100%. Perhaps both.
Dave LaRonde
Promotion Producer
Dave LaRonde
on Jul 29, 2018 at 4:09:20 pm
I agree. I see nothing wrong with the text. I see other things in that small shot, and I assume they are other layers in the comp.
Dave LaRonde
Promotion Producer
Corey Curry
on Jul 29, 2018 at 10:38:19 pm
Are you talking about the pixels? Is the quality set to quarter?
Jim Scott
on Jul 29, 2018 at 11:07:27 pm
You've either got the resolution set to something less than Full, as Corey asked, or you have magnified the Comp window above 100%.
