Keyframe Stroke on Shape Layer
Keith Robertson
on Jul 26, 2018 at 3:15:45 pm
Hey everyone, got a fairly easy question but I couldn't seem to find an answer for it so I thought I'd just make a post.
I'm trying to keyframe a stroke increase across all of the shapes within a shape layer. Is there any way to do that without having to keyframe the stroke on every single shape within the layer? I'm hoping that's the case but if someone could give me a definitive answer, that would rock!
Thank you!
Corey Curry
Re: Keyframe Stroke on Shape Layer
on Jul 27, 2018 at 3:25:17 pm
Your best solution is to animate it from shape, and then when you're finished copy and paste the stroke effect into the other shapes.
Also worth mentioning is that you could put one stroke effect under all the shapes. The problem is it outlines everything combined.
