Adding a mask to my pre-comp negates the adjustment layers inside it.
Andrew Davies
on Jul 25, 2018 at 2:47:14 pm
Inside a precomp I have a colorama effect on an adjustment layer along with a few other layers. In a Master comp, I've placed the precomp and turned on CR so that all the layers underneath in hte Master are affected by the colorama effect. Now I want to animate a circular mask over the precomp so that all it's layers, including the adjustment layer effect, are masked at the same time, but whatever I try negates the colorama effect.
So far I've tried:
- applying a mask directly to the precomp
- applying a circle effect on the precomp
- using a separate layer as a track matte
Is this a known limitation of precomping adjustment layers? Are there any work-arounds?
Andrew
Steve Bentley
Re: Adding a mask to my pre-comp negates the adjustment layers inside it.
on Jul 25, 2018 at 4:02:14 pm
Its the continually rasterize button that's causing the "issue".
What about just putting the colorama effect on each layer in the precomp and linking the effect's values to a master effect via expressions? That way when you change one you change them all.
Andrew Davies
on Jul 25, 2018 at 6:31:41 pm
the colorama effect is to affect the layers in the Master comp not the precomp so linking via experssions won't work.
Thanks though.
