Saber and 3D stroke
Nick Bruzek
Saber and 3D stroke
on Jul 16, 2018 at 12:57:10 pm
I'm on After Effects 2015, and I've been working on an intro, and I can't seem to get these two to work together. Is it possible to use Saber and 3D stroke together, or is it just wishful thinking?
Jim Scott
Re: Saber and 3D stroke
on Jul 16, 2018 at 11:14:14 pm
Yes it is. But that's a pretty wide-open question. What are you trying to do?
12549_3dstrokeandsaber.mov.zip
Richard Garabedain
on Jul 17, 2018 at 2:54:27 pm
Saber is a 2d effect and 3d stroke is a 3d effect. Ive gotten saber to work with element 3d by tracking the 2d saber onto 3d footage but saber cannot be rotated without turning flat so its probably wishful thinking. Unless your camera is static. at which point you could just apply the same path to both saber and the stroke...so you might be able to do it that way...pre compose and then animate a camera.
