Duik & Puppet Pin Problem - Won't render!
Rob Mason
on Jul 14, 2018 at 7:10:21 pm
So I have a phone and cord that I animated in AE using Duik + Puppet Pins for the cord. When I go to render, the only thing that renders is the phone, not the cord (which I have the pins on).
I should also note that I used Duik to create Bones out of the pins.
Why is this happening?! I have tried every rendering option available (to my knowledge). These are only simple shape layers, precomped, with added puppet pins and Duik Bones...
I have already tried:
* Turning Rasterize off in all precomps (and turning it on in all of them)
* Turning all layers to 3D (and off)
* Purging Cache
* Making sure the FPS in each precomp is the same (also in render settings)
* Turning on Preserve Frame Rate , as well as Preserve Resolution in the comp settings
* I have the most up-to-date version of Duik
* Yes, I am in Active Camera mode
* Turning off all other layers
* Copying assets in question over into a new comp by themselves
PLEASE HELP!
Steve Bentley
Re: Duik & Puppet Pin Problem - Won't render!
on Jul 14, 2018 at 10:57:26 pm
Can you upload the file and we'll take a look? What version of AE and Duik are you using?
