Adobe After effects watch folder
jeffin ravi
on Jul 11, 2018 at 7:51:29 am
I am saving an After effects file in a watch folder which is being watched by Adobe media encoder using extendscript , the problem is all the compositions are rendered to a video by adobe media encoder, I want to instruct the AME to export only one composition(the main comp) from the project, Is there any way around to achieve this?
Dave LaRonde
Re: Adobe After effects watch folder
on Jul 11, 2018 at 6:00:14 pm
You can send the comp in question to AME, which lets you continue to work in other applications.
Dave LaRonde
Promotion Producer
Walter Soyka
on Jul 11, 2018 at 7:02:59 pm
[jeffin ravi] "I want to instruct the AME to export only one composition(the main comp) from the project, Is there any way around to achieve this?"
When you drop an .AEP file into an Adobe Media Encoder watch folder, AME renders all the comps contained in the root level of the project. Tuck all the comps you DON'T want to render into a folder before saving the AEP and you should be able to render only the main comp.
Walter Soyka
