Spectator effect for the background
Steve Davies
on Jul 10, 2018 at 3:09:23 pm
I am trying to get a simple background that gives the impression of spectators in the background of a football scene. I basically need circles to idealy jump up and down as if they are cheering. The simplest but longest solution might be to animate them individually but when ever I do that the position goes all wrong.
I thought would try using an expression but isn't quite what I am after. Would anyone recommend a technique.
Here is my attempt
And I am after something more like this:
https://dribbble.com/shots/1688010--And-the-crowd-goes-wild
Digital Designer
stevedavies.io
Walter Soyka
Re: Spectator effect for the background
on Jul 10, 2018 at 4:23:12 pm
I would create a set of maybe 3-6 small, looping comps that feature one individual circle doing its own cheer, all with exactly the same duration.
Then, I'd either use expressions or a script to position them, looping them and randomizing their start times, or I'd use a particle system like Form to distribute them.
To use Form, you'd have to sequence your individual comps into one precomp that contains all of them, again, with exactly the same duration for each. Then set Particle > Particle Type to Textured Polygon, Texture > Layer to your all-animations precomp, Texture > Time Sampling to "Split Clip - Loop," and Number of Clips to match the number of comps in your all-animations precomp.
Walter Soyka
Steve Davies
on Jul 11, 2018 at 8:28:30 am
Walter, thanks, I am strugging to follow your settings but I think I am missing something
I don't seem to have the time sampling option to split clip - loop, unless I am applying CC Particle World to the wrong layer?
Steve
Digital Designer
stevedavies.io
Cassius Marques
on Jul 11, 2018 at 7:07:46 pm
Walter is talking about a setting in Trapcode's Form plugin. I'm almost certain you can't do that with CC particle World.
Cassius Marques
http://www.zapfilmes.com
Steve Bentley
on Jul 12, 2018 at 11:01:20 pm
What about just duplicating your "head" layer but first put a small wiggle expression on it. The layer number of each duplicate will change the random seed of the wiggle so each is slightly different.
Steve Davies
on Jul 16, 2018 at 2:04:10 pm
This would work but I would need to duplicate the layer 100's of times, if I am understanding right.
Digital Designer
stevedavies.io
David Byrne
on Jul 17, 2018 at 12:56:42 pm
Here's an attempt to help you out -
12551_simplecrowdnoparticles.aep.zip
Its a crowd of 100 shaded dots moving independently. You can easily drag this comp into another, duplicate it and reposition to make larger crowd sizes.
It has a 'Crowd Control' master layer that you can change the tint of the crowd easily, or checkbox for a rainbow colour effect.
You can also control the speed and movement of the dots.
To affect the size of the dots simple change the size in the sprite control. Warning - too much movement or size difference may become noticeable when they interact due to the shading layer (a fractal noise adjustment layer).
BUILT as follows -
(this isn't exactly the same as I did it, I have simplified dimensions for ease of instruction)
I made one Dot, a circle shape layer, in a 100x100 comp. I then animated the position properties with a wiggle setting of
s=wiggle(comp(2,10);
[s[0]/4,s[1]];
That is - 2 times a second the dot moves vertically up to 10 pixels in either direction (up and down) and a quarter of that speed and amount left to right. I made the comp 30 seconds long.
I then dragged this precomp into a new comp ten times the width to make my row of cheering dots.
[Comp Width (1000x100)]
I duplicated the dot 9 times. Using Align and Distribute I quickly selected one dot and moved it far left, another far right, then selected all layers and using the Distribute panel selected Distribute Horizontally (the fifth option from left).
Now I manually dragged the layers to the left at random amounts. This is to taste - just enough that the particles move at a different speed to each other.
I then moved this 'Row of Fans' precomp into a grid precomp and again duplicated it 9 times. Moving one row to the top, one to the bottom I then selected all layers and Distributed Vertically.
Again I manually dragged the layers to the left at random amounts. This is to taste - just enough that the particles move at a different speed to each other.
Now I added shading. I added Fractal Noise layer, set to Basic Block, 1.0 Complexity, Adjusted brightness and contrast to taste. I also scaled down to make it roughly 10 x 10 boxes. And changed blending to overlay.
Finally I precomposed all this into a Master comp - in my case I linked up some expressions to change colours, speed, etc from the master comp so no need to dive in, plus of course that means you could animate the crowd cheering a goal for example.
Hope this helps, happy to answer any questions and of course take suggestions.
Cheers!
Dave Byrne
Animo Motion Graphics
Freelancer, UK
Steve Davies
on Sep 13, 2018 at 11:06:28 am
I never got to thank you for this! Thank you!
Digital Designer
stevedavies.io
David Byrne
on Sep 13, 2018 at 11:44:30 am
You're welcome!
Cheers!
David Byrne
Freelancer, UK
Richard Garabedain
on Jul 17, 2018 at 2:57:12 pm
go to a stock footage site and look at videos of crowd cheering motion graphics...its a blur of motion and camera flashes. look at inspiration before you work...every time
