Create a slideshow template to use in Premiere Pro
Lisa Newton
on Jul 10, 2018 at 9:04:18 am
Hello 😊
I need to create about 70 slideshows all based on the same template...same number of images, same simple animations, same duration. I'm just not sure about the most efficient way to produce the master template. Basically, I want to create a slideshow in After Effects and drop the new images onto the template multiple times in Premiere Pro. Can I create a mogrt with placeholders for the images? Could I use dynamic links?
I'm using mogrts for the text animations but can't work out how to simply swap the images in a drag & drop manner.
Lisa
