Repeating Text with Text Sourced from Another Layer
Clayton Glenn
on Jun 28, 2018 at 7:35:17 pm
Trying to get this to work, getting a text sourced from another layer to repeat a given number of times. In this case 5.
Beginnings work
s = "";
for (i= 1;i <= 5;i++) s +="source from other layer";
s
For a layer named layer name I am trying to get it to replacy the "source from other layer";
Using a pickwhip from the chosen layer, EXAMPLE with live type,
thisComp.layer("EXAMPLE").text.sourceText
It doesn't seem to see it as a source and returns that it is expecting a ;
Any ideas? Many thanks for the time.
Clayton Glenn
Re: Repeating Text with Text Sourced from Another Layer
on Jun 28, 2018 at 9:15:30 pm
This may be better suited in After Effects Scripts forum... Apologies, I'm figuring out the forums here.
Best wishes,
Saving the world one pixel at a time.
Kalleheikki Kannisto
on Jun 29, 2018 at 5:26:49 am
[Clayton Glenn] "and returns that it is expecting a ;"
This seems to indicate you're missing a ";" at the end of that line.
Senior Graphic Designer
Walter Soyka
on Jun 29, 2018 at 9:38:53 am
This works exactly as expected:
s = "";
for (i= 1;i <= 5;i++) s += thisComp.layer("EXAMPLE").text.sourceText;
s
If you're still having trouble, please copy and paste the code you have that isn't working.
Walter Soyka
