Weird visual bug
Victor Gagnier-Tétreault
Weird visual bug
on Jun 28, 2018 at 6:15:22 am
I have a composition which contains precomps and I control their position on the X axis with a single null object that acts as a camera.
But, there is one precomp of a character which is acting quite strange.
The further this comp moves on the X axis, the more this one shape layer inside of it gets messed up.
I even tried moving the shape layer outside of the precomp but that still did not fixed it.
Disabling collapse transformations fixes it but makes the layer quality horrible.
Here are some screenshots to prove the problem:
Inside of the caracter precomp, as you can see it's looking normal.
Inside of the main composition, before the null object moves the precomps
and, this is where the visual bug appears, after the null object controls the precomp based on it's X axis.
He are my specs:
Windows 10
16 GB of Ram
I7-8700 CPU
GTX 1050Ti 4GB GPU
My AE version is 15.1.1 (Build 12)
Any help would be very appreciated as I am clueless on how to fix this.
Richard Garabedain
Re: Weird visual bug
on Jun 28, 2018 at 10:24:07 pm
go into the pre comp and make sure all the layers are 3d....other than that i cant really tell what is going on
on Jun 28, 2018 at 11:23:21 pm
I checked the 3D boxes of every layer in that precomp and... that fixed the problem!
I can't believe that this was causing this whole visual bug!
To say the truth, I tried doing everything but that...
Thank you for your help!
Richard Garabedain
on Jun 29, 2018 at 6:32:25 pm
we have all been there...lol
