Adding wrap-around screen to 3D render
Ellis Berman
on Jun 27, 2018 at 6:10:30 pm
Hi folks,
I'm trying to find the easiest way to get a piece of footage to wrap around a 3D render of a TV screen. See attached
See that little corner bend? What's the easiest way to accomplish this?
Walter Soyka
Re: Adding wrap-around screen to 3D render
on Jun 27, 2018 at 6:28:47 pm
Make two precomps: one for the square piece, one for the corner piece, both fed by the full-width source image. Use CC Power Pin to put each precomp in its respective place over the render, and use track mattes to handle any places where the image should be obscured (like the bend of the column on the left).
Walter Soyka
Ellis Berman
on Jun 27, 2018 at 7:05:11 pm
Cool, but that's already what I sorta did with the corner pin tool. The issue is I want the two pre-comps for the square screen and the corner screen to look like one piece of footage.
Walter Soyka
on Jun 27, 2018 at 7:13:58 pm
I guess I don't understand what you mean by "look like one piece of footage." Are you trying to show a projection effect where it looks like the screen doesn't bend at that corner?
Walter Soyka
Ellis Berman
on Jun 27, 2018 at 7:23:29 pm
No, I'm trying to make it look like one big screen with a bend - have the footage wrap around the screen, like this iphone -
Sorry this is a bit confusing - thanks for the patiences. :)
