temporal median for background subtraction?
philipp hahn
on Jun 25, 2018 at 3:44:46 pm
hi,
i'm a little surprised i found almost nothing about this, maybe it's the wording? anyway:
i want to key using background subtraction (in ae it's called "difference matte"), but as my matte i do not want to use a still image or a video from another source but the very same video, only with a temporal median applied - so each pixel is calculated from the median color value at its location of eg. 50 frames back and forth. the result of this should be, that i only key stuff, that moves at a certain pace whereas very slow changes in the shot (eg. moving light from the moving sun) will still be keyed out.
this technique is also often used to remove people in crowded shots, eg.: https://www.shutterstock.com/blog/photoshop-remove-people
how would i do this in after effects? or is there any other software i should be looking at?
thanks for any help in advance!
p
Steve Bentley
Re: temporal median for background subtraction?
on Jun 25, 2018 at 6:11:26 pm
I haven't seen the code but given how we have used Mocha in the past I would imagine this is being employed at some point in the pipeline. To be fair, we have pro, so I'm not sure how robust the one that comes with AE is.
Roei Tzoref
on Jun 26, 2018 at 12:07:36 am
here's a tutorial using difference matte from the same video. if you have a shot for us to see and test and can share, please do
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
philipp hahn
on Jun 26, 2018 at 4:55:20 pm
thanks for your help but, um, which of these tutorials should i be looking at? there are four 10+ minute tutorials behind this link and at least on first sight, none seems to say anything about temporal median... or did i miss something?
best
p
Roei Tzoref
on Jun 26, 2018 at 8:13:11 pm
Forgot the link:
http://motionworks.net/after-effects-difference-matte/
Roei Tzoref
philipp hahn
on Jul 8, 2018 at 6:09:25 pm
hello again,
sorry for the delay, for future reference:
roei's tutorial video uses photoshop to create a median clean plate, which does work nicely for individual clips/shots but unfortunately i'm dealing with a lot of frames and photoshop crashes on these quantities.
the solution i'm currently exploring and which seems most promising is not using after effects or photoshop at all but to do it from the command line using G'MIC, details are explained here: https://discuss.pixls.us/t/a-guide-about-computing-the-temporal-average-med...
again, thanks for all the help and have a wonderful day!
p
philipp hahn
on Jul 8, 2018 at 6:57:17 pm
sorry, forgot something, also interesting: https://github.com/zo7/median-video
