After drawing a mandala path with Particular, is it still possible to keyframe its shape properties?
Benjamin Sintemaartensdijk
on Jun 13, 2018 at 8:52:50 pm
First post after ma(aaa)ny anonymous visits, so thank you already for all the help you've been providing! 🐮
Hopefully these screenshots help clarifying my issue. When I grab the particle emitter (Light 3) in the viewport it behaves exacly how I want it to. But is there any way to keyframe this?
https://imgur.com/a/CyFs3iE
Is it possible to uniformly manipulate the entire shape, AFTER its path/trajectory has been calculated?
Artist, designer, creative.
http://www.benjamindesign.nl
Kalleheikki Kannisto
Re: After drawing a mandala path with Particular, is it still possible to keyframe its shape properties?
on Jun 14, 2018 at 6:28:50 am
You will have to adjust the formula and re-render. But you might even be able to render the whole shape in one frame, which would give you the result you're after. If not, there's always time remapping.
Senior Graphic Designer
