Batch replace DPX footage
Diana Yuen
on Jun 12, 2018 at 6:30:08 pm
is there any script or ways that i can relink xml with dpx ?
as offline editor using Quicktime to edit in premiere, and the xml will linked with the quicktime.
however, we will do colour grading before comp in AE, which will export DPX, is there any ways relink those quicktime with DPX as there is so many shot which is time consume if i relink manually. (as the dpx files locate in different folder and with timecode suffix)
Eric Santiago
Re: Batch replace DPX footage
on Jun 12, 2018 at 7:31:52 pm
How crazy is the naming on the files?
I've had to use XML editors for something like this.
I use Oxygen XML editor not sure if that will work for you.
Diana Yuen
on Jun 13, 2018 at 4:26:01 am
like 50 shot seperate in 50 different folder, means i need to relink manually for 50 times
