Warp Stabilizer Vertical Bounce/Stretch?
Michael Dominic
on Jun 7, 2018 at 1:47:00 pm
I'm stabilizing some footage and I notice that the WS at times compensates by stretching the footage vertically, making it look elastic, I have tried multiple settings but have not found a remedy.
Michael Szalapski
Re: Warp Stabilizer Vertical Bounce/Stretch?
on Jun 7, 2018 at 2:17:41 pm
I've not noticed it stretching it a whole lot vertically. Can you share an example of what you mean?
- The Great Szalam
Michael Dominic
on Jun 7, 2018 at 3:00:24 pm
Michael Dominic
on Jun 7, 2018 at 3:01:22 pm
Look at the sky.
Richard Garabedain
on Jun 7, 2018 at 3:02:25 pm
set it to fix by position and scale only. sometimes the perspective warp does not work just right
Michael Dominic
on Jun 7, 2018 at 3:48:17 pm
There is only the option for "Position, Scale and Rotation", not only position and scale. I tried it and it causes other oddities.
Blaise Douros
on Jun 7, 2018 at 3:54:58 pm
Reduce the amount of stabilization to reduce these jello effects. It defaults to 50%, so dial it back to 15% and then go up from there. You'll find that you get acceptable results with much less stabilization than you'd think.
Michael Dominic
on Jun 7, 2018 at 4:09:02 pm
Thanks.
