Time remap using luminance or control layer
chris monaco
on Jun 6, 2018 at 4:15:28 pm
Hello,
I'm trying to figure out how to control time remapping of 45 flickering boxes by using the luminance of another layer or a script of some kind. Below is a video tutorial I found for scale but it is not exactly what I am trying to do.
45 boxes fill a 1920x1080 comp. I want to be able to animate a ramp in random places around the 1080 comp so that the smaller boxes will be triggered only in the area the gradient lives. I also want the boxes to animate off if the gradient moves out of it's vicinity.
I tried controlling this with a time displacement but it doesn't give the kind of control I am looking for. I am thinking I need help setting this up with some sort of control layer or something. Any ideas out there?
Thank you
Chris Monaco
Motion Graphics and VFX Artist
http://www.chrismonaco.tv
Steve Bentley
Re: Time remap using luminance or control layer
on Jun 6, 2018 at 4:43:05 pm
First, each box would be a precomp and in the precomp would be a timeline of all the animations that box should do. Could you not then use expressions in the outer comp to sample the luminence at the spot a particular box sits at and then send the play head of that precomped box to the frame appropriate to that luminence level?
chris monaco
on Jun 6, 2018 at 6:42:23 pm
Is there a way to do this with a script?
Chris Monaco
Cassius Marques
on Jun 6, 2018 at 8:29:18 pm
That's actually pretty simple. Its just one expression. I've made and example: 12434_sampleluma.aep.zip
Note that I'm guessing the luma source as greyscale, so I'm just sampling the Red value.
Cassius Marques
http://www.zapfilmes.com
