Scale a rounded rectangle in a non uniform way without edge deformation
James Brockett
on Jun 4, 2018 at 4:03:51 pm
Has anyone had success scaling a rounded rectangle? I am attempting to scale a rounded rectangle from a widescreen shape to a portrait phone screen shape (not a uniform scale) and whenever I scale the rectangle in this fashion my rounded edges become notably off and deformed. I have tried changing the roundness with the rectangle and also using a mask shape and transforming the path instead of the shape with the same results.
Kevin Camp
Re: Scale a rounded rectangle in a non uniform way without edge deformation
on Jun 4, 2018 at 6:45:58 pm
it depends on how the rounded rectangle was made.
If it is a rasterized layer (like a png) then you won't be able to do it.
if it was made as a mask on a layer, then you won't be able to use the scale property, but you could select point and move them manually.
if it was made as a shape layer, then you'll want to use the size property (contents>rectangle #>rectangle path #> size) to change the width or height while maintaining the roundness of the corners.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
James Brockett
on Jun 4, 2018 at 7:03:51 pm
Thank you so much that was it! I never usually had problems scaling my shape layers until now, I forgot there was even another way to transform the shape that wouldn't destroy the edges.
Kalleheikki Kannisto
on Jun 4, 2018 at 6:47:37 pm
To retain correct corner rounding, the rectangle shouldn't be scaled, rather you should adjust the width and height parameters.
Senior Graphic Designer
