keep text formating while adding substr() expression.
Ranveer Singh
on Jun 4, 2018 at 12:09:29 pm
I have a pretty simple text layer with a color on few alphabets. Now as soon as I am using substr() expression on it, it loses all of its formattings. Is there any way to apply substr() without losing color?
Kalleheikki Kannisto
Re: keep text formating while adding substr() expression.
on Jun 4, 2018 at 6:56:18 pm
You will likely want two or three text layers, one with your substring expression on it and the other(s) with a position expression to keep the texts together as if they were in the same text box.
Senior Graphic Designer
