C4D/Particle Mesh/Cineware Issue
Tristan Casey
on May 25, 2018 at 10:47:33 am
Hi, I'm having a problem with Cineware not showing my particle mesh from my C4D import file. am I missing something? I've tried adding an external compositing tag and adding it to a layer. It just won't see it. anything else I add to the scene is recognised.
Please help!!!
Steve Bentley
Re: C4D/Particle Mesh/Cineware Issue
on May 25, 2018 at 5:08:38 pm
Is it possible its coming in at a scale that doesn't let you see it, ie too small? Or could it be that with C4d's Y coord being upside down from AE and the center being offset as well it's just outside of your viewing window in Ae?
Tristan Casey
on May 25, 2018 at 7:48:57 pm
I don’t think so as my mesh is smaller than the grid in Cinema. It’s just text being filled. Cinema renders it fine so why can’t I see it in Cineware? I’m up to date with CC 2018 but I’m stuck with Cinema R13.
