Preview turns black when I add a rotation keyframe
Luiz Carlos Carvalho
on May 24, 2018 at 1:27:52 am
12410_screenshot3.png.zip
My After Effects (CC 2015) preview turns black when I add any rotation keyframe and stops rendering (it doesn't happen when I add a position keyframe).
12412_screenshot1.png.zip
It does work again when I disable the transform.
Could someone help me? Thanks!
Mark Whitney
Re: Preview turns black when I add a rotation keyframe
on May 24, 2018 at 5:08:35 pm
You've an expression on Transform along with a Wiggle effect so one of those is "competing" & moving your layer out of view I'm guessing. Try disabling just one or the other to isolate the culprit. You might try a custom view to see where it's getting moved to as a clue if it's rotation or translation.
Also, you might try moving the wiggle effect below the transform effect to see if stacking order is a factor.
on May 27, 2018 at 3:25:44 pm
Found out my RSMB plugin was in conflict with my Transform, probably a bug. Thank you anyway.
